13,000 Sq. Ft. SIP Home
Last Post 27 Oct 2012 06:32 AM by cmkavala. 44 Replies.
Page 2 of 3 << < 123 > >>
Author Messages Informative
28 Apr 2012 12:28 PM
I've seen new hotels (about the size of this house :-)) going in with each room having an independent mini-split (vs any type of centralized system). I assume that they found this economical. Also far less disaster prone (ie, a centralized system failure).
28 Apr 2012 12:30 PM
Posted By Lbear on 28 Apr 2012 01:36 AM
Posted By Dana1 on 27 Apr 2012 04:11 PM
It's a kewl looking house, but it's a hygro-thermal nightmare, lacking capillary & thermal breaks, with huge heating & moisture related problems, as well as basic mechanical issue (sagging cantilevered concrete elements, etc.) It's been patch, jacked up and reinforced multiple times, but like the leaning tower of Pisa, long term prospects are dependent upon a significant ongoing engineering & repair budget.
But it's a pretty picture to look at, as long as you don't have to live in it, eh?
FLW was ahead of his time and unfortunately insulating technology lacked behind his designs. Of course when you build a home into the side of a waterfall and have a creek running through the home, one can only expect huge moisture related problems. If the home was built in a "normal" location, it would not have the same engineering and upkeep problems. The waterfall design incorporated concrete and steel. At least they didn't use wood, as it would have long rotted and fallen away.
The cantilevered concrete overhang was WAY under designed, and would have the same structural problems in any location. (In seismic zones it would be condemned.)  The moisture problem is just the moldy frosting on the cake.
28 Apr 2012 01:52 PM
Posted By jonr on 28 Apr 2012 12:28 PM
Most motels use package units rather than mini split sand usually carry spares that allows them to easily slide the chassis in and out of the wall case when a failure occurs.
28 Apr 2012 01:53 PM
Posted By ICFHybrid on 28 Apr 2012 09:11 AM
6" walls and roof, 10.5 tons
Ha ha, it's so big it makes the panels look smaller than that.
7 split split heat pumps
What's that? Is that a ductless system?
What kind of thermostat and control system does it have?
a normal "split" system is ducted with air handlers and condensers, in this case 7 of each or 7 zones
28 Apr 2012 02:54 PM
They are called "PTAC".
It's basically a complete unit that has A/C and heating strips, some have heat pumps in them. They usually sit below the window and they have a metal sleeve that the unit sits in. As mentioned here, if he needs to be repaired it can be easily slid out and a new unit slid in.
Some hotels utilize corner PTAC units and those are vertical units that are usually hidden behind a paneling system.
These PTAC systems have been in use for many years now. I believe they go back to the 1970's.
28 Apr 2012 02:55 PM
Posted By cmkavala on 28 Apr 2012 06:03 AM
Will they be furring and doing drywall on the interior walls/ceiling?
28 Apr 2012 03:08 PM
Lbear; yes - 1-1/2" steel hi-hat furring on walls, 7/8" steel Hi-hat on vaulted ceilings. many custom drops with light guage framing
28 Apr 2012 03:10 PM
after Day 2....................................................................................
28 Apr 2012 05:33 PM
All I can say about this house is wow! that's "a-big-un". Nice catch Chris. You are definately doing some of the most interesting metal sip projects out there.
13 May 2012 07:15 AM
15 May 2012 03:01 AM
What is the OLDEST metal SIP home/roof that you have seen? Were they around in the 1970s for residential?
15 May 2012 07:07 AM
Posted By Lbear on 15 May 2012 03:01 AM
Lbear;
I have been involved with metal SIPs since 1995, the older SIPs homes that I have personal knowlege about is in the late 80's
Commercially they date back to a least the 60's, maybe earlier
15 May 2012 09:51 AM
Posted By cmkavala on 15 May 2012 07:07 AM
Lbear;
Have you seen any issues of weathering or glue issues with the ones from the residential 80's or the commercial ones from the 60's?
15 May 2012 10:22 AM
I have not seen any issues with EPS , only adhesion issues with Polyurethane, but no weathering issues with either
15 May 2012 03:54 PM
Posted By cmkavala on 15 May 2012 10:22 AM
So in theory these homes and roofs can still be intact 50 or 100 years from now? No glue failures and subsequent structural failure of the panels.
I'm just wondering HOW LONG can these panels stay together? A fastener can hold a piece of wood in place for 100 years and can be refastened even later on. If the glue came apart and the panel broke away from the EPS, the house would start to fall apart.
Just wondering...
15 May 2012 04:59 PM
Posted By Lbear on 15 May 2012 03:54 PM
Just wondering...
Yes , the same "theory" that holds together laminated plywood, glulam beams, TJI's and the like.
I don't hear a lot of failures for those products unless they get consderably wet.
Even auto manufacturers are now bonding together parts with glue
25 May 2012 09:58 PM
Posted By cmkavala on 15 May 2012 04:59 PM
Just wondering...
Good points. Plywood, OSB, and other laminated wood structures are glued together. I believe they use heat and pressure as part of their manufacturing process.
With steel SIPs they are just glued, no heat, correct? How stringent is the quality control on the SIPs?
26 May 2012 08:07 AM
Posted By Lbear on 25 May 2012 09:58 PM
Just wondering...
Lbear;
Not all steel SIP production lines are made the same.
The product we use is run on a continuous line machine in a controlled environment, the glue is a faster setting and as the panel travels thru the machine a set of rollers add pressure and heat to assist in the final bonding of the skin to the core.
04 Jun 2012 10:19 PM
updated photos. ...........................
05 Jun 2012 06:37 AM
Building is 83 feet wide with a triple hip in the back and 123 ft. deep.
People Online People Online: Visitors Visitors: 195 Members Members: 0 Total Total: 195
