Posted By richm on 30 Mar 2013 06:53 PM
Does anyone know the difference between these two companies? Both in GA (not far apart); appears to be same CEO/owner; appear to be identical Steel SIPs.
Rich M.
It might be the same company but under different LLC's?
Sometimes businesses split up like that under different company names but it's the same product. Some ICF manufacturers use the same EPS foam factory but they label the ICF under different company names, even though the ICF design is coming from the same factory.
Rich M, you are correct, PFF and Permatherm are both quality steel SIP manufacturers/distributors. I've never read or heard anything bad about them.
