Finishing Interior SIPs panels
Last Post 04 Apr 2013 11:53 AM by trigem1. 2 Replies.
mpedersenUser is Offline
02 Apr 2013 08:02 AM
I recently began working with SIPs panels, primarily OSB clad. We have used the fiber cement panels for at least one project in the past and may use them again in future projects. I was curious to know if it is possible to forego drywall on the interior side of the fiber cement panels and simply finish the panel itself. It seems like it could be done but I would be worried about what would happen when the panels shift/settle. I haven't been able to find much on the topic and was wonder if anyone had experience with or opinions on the possibilities.
02 Apr 2013 08:18 AM
Posted By mpedersen on 02 Apr 2013 08:02 AM
mpedersen,
I think the answer is in your question,
if something shifts or settles - expect cracking
trigem1User is Offline
mpedersen,
A customer and I once bounced the idea around about just taping the seams and using a texture sprayer and spraying texture right on the OSB, then spraying primer and then paint, thereby saving a lot of time and money. While that might work OK in a non-attached garage, local fire codes required a layer of drywall in the home or attached garage. So, simply from a fire prevention or protection stand point, drywall is a very good idea.
Steve
GrandCountySIPs.com
Steve Etten
People Online People Online: Visitors Visitors: 183 Members Members: 0 Total Total: 183
