Posted By kited on 27 Aug 2015 05:30 PM
I've heard that one way to finish the interior of a metal SIPs home is to add furring strips and hang drywall. I'm looking into alternatives to accomplish a couple of things: 1) I'd like to recess outlets so they don't stick into the room. 2) I'd like to make a wall more maintenance friendly. That is, if I want to add speaker wire or Ethernet down the road, I'd like easy access versus traditional wire fishing.
One idea I have is an internal framing, say 2x4's or 1x3's with drywall over it. The drywall would not reach the floor (about 6-8" higher) or the ceiling. Top and bottom of the drywall would be finished with plastic to make the edges nice, and then there would be a finished wood piece top and bottom that could be removed (unscrewed?) to run wires. Outlets would point down in that open space at the bottom for recessed plugs.
My questions are: would that be permitable for fire rating? Would the carpenters hate me? Can drywall "hit" 1x3 framing like that? How would I attach to the metal SIP? Furring again? Noise dampening furring mounts? .
Thanks as always for humoring me!
Kited,
the purpose of the furring strips is so the boxes will be recessed,
1 x3's or 1 x2 's will work or 7/8" steel hi-hat furring or 1-1/2" steel hi-hat works the best, that way the electrician can utilize a 4 x 4 x 1-1/2" deep box with plaster ring for most outlets
there is no fire rating required by code, but there is a 15 minute "THERMAL" barrier required.
1/2" drywall 3/4" wood meets the requirement, but plastic would not,
attach wood furring strips with #8 x 1-5/8" coarse thread drywall screws or equiv. / and steel furring with #10 x 3/4" sheet metal screw
