Thermocore Banner
Find a Green Building Pro
Browse Project Albums
View Product Guide
dcook4User is Offline
04/04/2008 2:33 PM
If I were to build a house with ICP for the basement and SIP for the frame of the main level and roof, is it neccessary to use SIPs for the floor as well.  What are the advantages and disadvantages to this.
04/04/2008 2:53 PM
Posted By dcook4 on 04/04/2008 2:33 PM
ICP? Do you mean ICF? You would not want to use SIPS for the floor unless the area below it was unheated. It sounds like all you really need is a standard TJI supported floor, and a nice touch would be to use a SIP rim.
....jc
cmkavalaUser is Online
04/04/2008 4:59 PM
No not necessary to use SIPS for floor;
advantages:
1. great insulation
disadvantages:
1.must run wiring, plumbing, ducts below floor (underside)
2. smaller spans
chris@southernsips.com
PremierCUser is Offline
04/05/2008 10:17 AM
dcook4
a panel floor is not needed, you could though if you wanted a warm floor feeling. We have installed 8" floor panel with TJI installed into the panels at the manufacturer and we were able to span 20'. We did put a support beam accros the middle to reduce deflection, but did not need it. the plumbers & electricians did not have any trouble doing their jobs. This project was an area that did not have basement are under it, this crawl space had 6 Mill poly down with 4" of pearock over the top. We vented this area into the basement.
Chris
Premier Construction
