American Polysteel
Find a Green Building Pro
Browse Project Albums
View Product Guide
Forums > Green Building Technologies > Geothermal Heat Pumps > Subject: Horizontal 2 Pipe Depth
davarUser is Offline
04/10/2008 2:24 PM
Hi my local geo loop installer says that he trenchs his two pipe horizontal at 5ftand 3.5ft.Most of what I have researched recommends 6ft and 4 ft.He says he has installed for ten years in Illinois ,Iowa,Indiana and Missouri and thats all it needs.I live in So Illinois and wonder if those depths are alright or will I lose a lot of effiency.Thanks for any advice
geodeanUser is Offline
04/10/2008 7:41 PM
The loop will perform fine at 5 & 3.5. You might lose a little efficiency. The difference in ground temp from 5' to 6' is not much.
OSHA rules don't allow working in a trench over 5' deep. There are ways to position the pipe with out being in the trench, but require more work. Is he using a trencher or back hoe? 5' is probably all the deeper a trencher will go.
PalaceGeothermal.com
Why settle for 90% when you can have 400%
We heat and cool with dirt!
visit- http://welserver.com/WEL0114/- to see my system
04/10/2008 9:51 PM
Thanks Dewayne ,for the advice.He uses a trencher and says he's never had any problem.
