BuildBlock Building Systems LLC
Forums > Green Building Technologies > Geothermal Heat Pumps > Subject: Keeping coaxial coil under pressure in open loop systems.
GeothermalmanUser is Offline
09/25/2008 1:48 PM
I have a potential customer who is going to switch to geothermal. He already has a shallow well for his sprinkler system, but NO pressure tank setup. On a call the pump come on and shuts off after the call. Sprinklers work great. I understand pressure in the coil in the off mode helps fight mineral formation in the coil, but does pressure or lack there of effect efficeincy during operation. We are on the east end of Long Island, NY. Water is high quality (sandy soil) and there is a spin down filter for sand particles already on the supply line.
Do I need to add the pressure tank
Any thoughts???
geodeanUser is Offline
09/25/2008 9:28 PM
Posted By Geothermalman on 09/25/2008 1:48 PM
Any thoughts???
pressure is not needed for the heat pump to work,  flow is the only factor.  However,  keeping the coil under pressure is recommended for the reasons you stated.
PalaceGeothermal.com
Why settle for 90% when you can have 400%
We heat and cool with dirt!
visit- http://welserver.com/WEL0114/- to see my system
Forums > Green Building Technologies > Geothermal Heat Pumps > Keeping coaxial coil under pressure in open loop systems.
