News/Blogs
Project Album
Directory
Products
Services/Advertising
Radiant Heating
> Subject: Good carpet choices over radiant?
Prev
Next
Author
Messages
Oldest First
Newest First
jbrown84
09/17/2008 8:55 PM
Does anyone have any recommendations for a specific brand/line of carpeting that has low R-values? I'm going to use a 7/16" slab rubber pad over QuikTrak, and I'm hoping to find a nice carpet to use.
Jeff
BadgerBoilerMN
09/18/2008 7:01 AM
Carpet padding often has a higher R-value than the carpet. 1/4" commercial pad is most often specified. Your choices are dictated by the heat loss of your room and the designed heat output of your radiant floor panel.
MA
www.badgerboilerservice.com
jbrown84
09/18/2008 7:32 AM
I'm already using a rubber pad with a low R value (0.45), but I'd like to find some carpet options that are low (relatively speaking).
BadgerBoilerMN
09/18/2008 8:13 AM
This is not particularly low. I stay away from carpets over 1/2" thick and wool of any kind.
Again; Your choices are dictated by the heat loss of your room and the designed heat output of your radiant floor panel.
MA
Brock
09/18/2008 4:26 PM
I would recommend something that is outside rated. They tend to be really thin and are meant to be used without a pad. I really would not put a pad of any kind under it; if you do you might as well not expect any heat from the floor, other then maybe a comfort heat and not any room heating.
Green Bay, WI. - 4 ton horizontal, 16k gallon indoor pool, 1kw solar PV setup, 3400 sq ft
Green Living
--<a href="http://discuss.greenoptions.com">Green Options</a>
Radiant Heating
Copyright 2009 by BuildCentral, Inc.
Terms Of Use
Privacy Statement
