Hi Brock,
Thanks for your reply, good to hear that you have my future setup, radiant staple up on a heat pump.
That is good information re the increased heat from #2 and #3.
For my info, can I ask you a few questions about your system?
1. What are the approx. dimensions of the plates you're using?
2. Do your remember the source of plates?
3. Are you using 1/2" pex?
4. Finally, on the heat pump question, is 90 deg the hottest you ever run - and did you try or consider a warmer temp?
Thanks for the good info!
Jeff
