Posted By manitoban on 13 Jul 2012 07:59 PM
Dana finally nailed it "Warmboard style" but the home made version of course!
I must admit after reading post after post suggestiing thermal mass you guys have convinced me to at least explore the possibilities. To follow through if I did plant the pex in 6" of crushed stone above the insulation and the V.B. how would one finish a floor like that?
honestly, if you must put it in something other than concrete, make it a sand bed. I have a lot of tubing in place and the rule of thumb is to always keep it away from sharp objects and that includes things that can, over time, through expansion create a hole in the tube. Think of that rope slowly rubbing on the rock that eventually works its way through (I'm from N.S. so pardon nautical reference). I have seen it happen.
If you are trying to do a warmboard equiv., that is fine but you won't be saving any money or energy and depending on the water temps, you may not like the sounds coming from it.
