Posted By Buntly on 02/17/2008 11:56 AM
Dmac, let me know if you go with dx system. I am curious as to what you think of the system.
Bunt
I've decided not to. Mostly based on cost. I'm going to be using a Daikin split system variable refrigerant volume air-to-air heat pump. It has a COP around 3 at 10°F. Auxillary electric doesn't kick in until 10°F. Our design temp for heat is 9F, which means the heat pump will be extracting heat from the outside air pretty much all the time.
If this heat pump didn't have the performance capability all the way down to 10F I'd still be going geosource.
Only time will tell if it was a smart move or not.
