Geothermal tax credits
Last Post 05 Jan 2009 08:52 PM by engineer. 90 Replies.
Page 2 of 5 << < 12345 > >>
cnygeoUser is Offline
07 Oct 2008 12:44 PM
Posted By 183eej on 10/07/2008 8:02 AM
Posted By Dan Kramer on 10/07/2008 12:14 AM
Would this credit apply to Air to air heat pumps as well?
It doesn't.  The credit is a renewable energy credit which limits it to geothermal.
I'm going to be pedantic and point out that air-source heat pumps are nearly as "renewable" as geothermal heat pumps. They both primarily use solar energy as a heat source. True, in most climates, a geo system may be able to use 20-30% more renewable energy in proportion to the electricity used, but there's no fundamental difference that makes gshps "green" and ashps not. Of course this is completely irrelevant since the only thing that matters is how the tax credit is written!
Serious question for the tax experts as I haven't found a decent summary of this yet. I started installing my system in 2007 (actually purchased the heat pump itself in 2006 and it sat in my garage for a year) but didn't bring the system fully online until early this spring. Is there any gray area I can take advantage of seeing as it was a diy install and I didn't consider the system complete until this year, or is the actual purchase of the components all that counts?
I realize tax advice from a message board is not going to fly with the IRS, but I'm hoping someone can tell me either "no way, don't even bother" or "it might be worth looking into".
07 Oct 2008 12:53 PM
Seperate but related question - is the new credit still only applicable to energy star rated heat pumps? This has always p***ed me off since hydronic heat pumps aren't energy star rated for the simple reason that there is no ARI standard to test them with! Maybe this will light a fire under the industry to get hydronic units rated - most good installs will easily meet the COP requirements.
Bill NeukranzUser is Offline
07 Oct 2008 01:29 PM
Posted By joe.ami on 10/07/2008 10:47 AM
Bill,
Don't despair. You've likely saved more than 2 grand by not waiting.
J
Joe, you're right.  Thanks for pointing out that I had 5 months of savings (reduced KWH consumption saving) last year in addition to the $300 tax credit.  This would be the correct comparison to whatever tax benefit I might otherwise have gained by waiting until this year to install my GSHP system.
I took a moment to look to see if I could quantify the savings since putting in geothermal.  Unfortunately, I don't have HVAC-only consumption numbers pre-GSHP installation (July '07) - i.e., an apples-to-apples comparison.
But at least to summarize where I'm at, geothermal consumption wise, for a Dallas climate:
We're consuming 23 KWH/day on avg, for HVAC only (including water loop pumps), and not including anything else, for a 3400 sf home.
It's a 10 month average.  With the next 2 months expected to require little HVAC, the coming 12 month average daily KWH usage should come down some.
183eejUser is Offline
07 Oct 2008 02:22 PM
Posted By a0128958 on 10/07/2008 1:29 PM
Bill,
J
Bill,
You should be able to back into the pre-GSHP costs to get an apples-to-apples comparison.  You have the post-GSHP history for the past 10 months so you should be able to calculate what the rest of the house uses for that same period.  If you take the average for the rest of the house over the 10 months and deduct it from what you paid the electric company before you installed your geo system, you should have a reasonable idea of what the old HVAC equipment was costing you.  If rates have gone up during this time, you might want to consider doing the math on the kwh and costing it at the last step.
It would be interesting to find out the results.  I built new so don't have anything like that to hang my hat on.
Dale Walker<br>EarthTap<br>www.earthtapenergy.com<br>Where the sun never sets on energy savings<br>
senecarrUser is Offline
07 Oct 2008 02:43 PM
Cyngeo in answer to both questions -
Before I looked up the 2007 form, I had thought it called for a qualified installer, but it doesn't. The form says "For credit purposes, costs are treated as being paid when the original installation of the item is completed, or in the case of costs connected with the construction or reconstruction of your home, when your original use of the constructed or reconstructed home begins." So, yes, if you finished installed it this year, you could make a justifiable case for it.
As far as rating the 2007 form refers to -
A closed loop geothermal heat pump that has an
EER of at least 14.1 and a heating coefficient of
performance (COP) of at least 3.3.
An open loop geothermal heat pump that has an
EER of at least 16.2 and a heating COP of at least 3.6.
A direct expansion geothermal heat pump that has an
EER of at least 15 and a heating COP of at least 3.5.
So I'm not sure if the COP must be that released by ARI ratings or what. It does say you can rely on the manufacturer's rating, so if the manufacturer gives it that kind of rating, you again might make a squeek. Failing to have an EER for most hydronic pumps might be a problem though.
http://www.irs.gov/pub/irs-pdf/f5695.pdf
07 Oct 2008 04:57 PM
Posted By 183eej on 10/07/2008 2:22 PM
Dale, thanks.  I took another look, this time at a macro level.  Instead of using my fancy WEL instrumentation system, I used the old fashioned electric bill paper copy.
Across an entire year (12 months), prior to installing geothermal, we consumed 144 KWH/day on avg, for everything.
After installing geothermal, for the past 12 months, we consumed 91 KWH/day on avg, again for everything.
This is a 53 KWH/day reduction, a 37% reduction.  See foot note below, though.
At our current 14.68 cents/KWH rate, we're saving $8/day, $237/month, or $2800/year as a result of installing geothermal.  That's $14K in five years w/o any assumption on future KWH rate increases.  (Wish I knew what might be valid assumptions for future electric rates for the Dallas area.)
Now back to Joe's comment to me about not waiting last year to proceed versus waiting until this year for better tax treatment:
Yes, indeed, we saved $1200 (5 months) in utility costs by proceeding in 2007.  Along with the $300 tax benefit from last year, that totals up to $1500.
Add in the fact we probably would not have done construction in Winter, with loss of heat for some time period (we were without any A/C for 4 weeks when we had geothermal installed last July).  This equates to about another 4+ months of lost utility savings, say $1000 based on current rates and usage.
So we would need to see a tax benefit from this year's legislative actions of approximately $2500, just to break even with the decision to proceed in '07 when we did versus now in '08.  Meanwhile, we've already had 14+ months to enjoy the nice, quiet geothermal system, along with improved dehumidified air, and the ability to set any room or rooms in the house to any temperature we want, no matter how hot or cold desired.
So, Joe's continually clearly correct - there's no better time to get going that the immediate moment, regardless of what's happening in the legislative or financial markets.
It's pretty clear - geothermal based HVAC is the real deal.
Foot Note:
A key assumption here is that our KWH usage pattern for the 12-month post-geothermal period is similar to the 12 month usage pattern prior to geothermal, and that no material changes have been made to the envelope of the home.
Indeed these assumptions are valid, with the exception that 3 months into the post-geothermal 12 month period we removed every incandescent light bulb and replaced them with CFL.
In another 3 months I'll be able to figure out the CFL impact using WEL data.  For now, I'll leave the CFL impact as simply a footnote.
07 Oct 2008 09:25 PM
Posted By senecarr on 10/07/2008 2:43 PM
Many thanks for the info - it might be worth pursuing after all. That's interesting about the ratings - it doesn't seem to mention Energy Star anywhere. I'm certain it did at one point because I corresponded with the manufacturer of my heat pump about it and they shared my frustration. It would certainly be good if they changed the rule to allow hydronic systems.
07 Oct 2008 11:15 PM
Posted By a0128958 on 10/07/2008 4:57 PM
Foot Note:
DFW Airport projected an 18% increase for the fiscal year beginning Oct 1.  One caveat is that the Airport assembled it's budget back in the spring.  Nationally, the economy has since hit a pretty rough spot and, accordingly, economic conditions may help keep the increase down but that is a pretty big assumption from my viewpoint.  The Texas economy is still moving forward and there will be more people moving into the state looking for jobs I belive so, long term, I think the 18% could be fairly accurate in spite of everything we read in the paper.  Historically for the past 6-8 years, we have experienced about 12% increases for electricity and 13% for natural gas and to be brutally honest, with a reluctance to invest in coal generators and nuclear taking a generation to get built, natural gas is what can get built the fastest and not let us run out of electricity.  Unfortunately, it is also the most expensive fuel we could buy for generating electricity.
How many tons did you install by the way?
07 Oct 2008 11:56 PM
Posted By 183eej on 10/07/2008 11:15 PM
... Historically for the past 6-8 years, we have experienced about 12% increases for electricity ...
OK, this is helpful, Dale.
If you take my $2800 annual savings and factor in 12%, then in 5 years, my savings will be
$2800
$3136
$3512
$3934
$4406
totalling about $18K.  This is of course assuming maintenance expenses are no different than with an ASHP or conventional HVAC.
My installer installed 8 tons total for a single-story 3400 sf home.  Two WaterFurnace Envision 2 stage variable speed motors, with one of the units having an attached 3-zone system.  All details are located here:  http://welserver.com/WEL0043/ .
08 Oct 2008 07:05 AM
Posted By a0128958 on 10/07/2008 11:56 PM
$2800
$3136
$3512
$3934
$4406
Bill,
Maintenance costs should be about 18-20% less for your geo system so, at 3,400 SF that should help your numbers by a couple of hundred dollars a year.  Getting that outside unit away from cottonwood trees and hail storms is a big help on maintenance costs.
Let's assume for a moment you paid $6,000/ton for your geo system and you could have paid $4,000/ton for a good quality air sourced heat pump.  In that example, you would have paid $16,000 more for your geo system.  The savings numbers above shows you will have gotten your money back in ~4.5 years.  Not bad.  The better story to me is the internal rate of return is 28% on this geo investment.  We're certainly not getting that kind of return from Wall Street.  That is awesome.
For people considering geo today, the $2,000 tax credit improves this return to 31% and the TXU incentive I just learned about yesterday for 8 tons of geo (~$1,200) increases the rate of return to 33%.
Now that is what I call green.
08 Oct 2008 09:33 AM
Dale
1. If you don't like burning natural gas for a fuel, I suggest you sign up with this guy's plan -
http://www.pickensplan.com/ -I'm on there somewhere, but not active in it.
2. How do geo systems have less maintenance?
08 Oct 2008 10:18 AM
Posted By 183eej on 10/08/2008 7:05 AM
Maintenance costs should be about 18-20% less for your geo system so, at 3,400 SF that should help your numbers by a couple of hundred dollars a year...
... In that example, you would have paid $16,000 more for your geo system.  The savings numbers above shows you will have gotten your money back in ~4.5 years.  Not bad.  The better story to me is the internal rate of return is 28% on this geo investment.  We're certainly not getting that kind of return from Wall Street...
... and the TXU incentive I just learned about ...
Dale, thanks.
I hope maintenance costs are minimal with GSHP.  While there's no outside unit anymore, we have a lot more 'stuff' up in the attic, where it gets very hot in the Summer (2 GSHP compressors and electronics, 3 water loop pumps, and zoning electronics).  And there sure is a lot of water pipe fittings, valves, connections, etc. up in the attic to constantly worry about leaks (none so far).
I agree that payback analysis needs to focus on the cost difference between replacement alternatives, not the total cost of a geothermal installation.  This is a point often missed by many.  With the residential market in the Dallas area being so one-sided toward conventional/ASHPs, I estimate my alternative difference was about $20K.
Can you point us to details on the TXU incentive you note above?  Thanks.
08 Oct 2008 04:16 PM
Posted By senecarr on 10/08/2008 9:33 AM
Dale
The maintenance info came from ASHRAE.  They estimate air sourced heat pumps need about 29 cents per SF for maintenance and geothermal needs 24 cents per SF.  No outside unit is a big part of the reduced maintenance I'm guessing.  In Texas at least, hail storms can bend the fins pretty badly and cottonwood lint, dog hair and a lot of other stuff get sucked into the fins and stop it up and strains the equipment.  100 degree summers down here are pretty harsh on the compressors too.
08 Oct 2008 04:22 PM
Posted By a0128958 on 10/08/2008 10:18 AM
Dale, thanks.
Bill,
I'll have to email it to you.  I tried to post it here and it exceeded 100kb.  When you get the form, I noticed in the bottom right corner it indicated TXU copyrighted it in 2007.  This tells me this program was around when you and I both installed our systems.  I'm up to my ears in alligators now but if you get into this and figure out we can squeeze a check out of these folks, please let me know and I'll sing at your next wedding for no charge.
BrockUser is Offline
08 Oct 2008 05:42 PM
Bill is your house all electric? Or did you have some natural gas usage in there as well? I am starting to figure out our new setup compared to our old. We are using the same electricity as our old house, but 2 therms of NG a month now compared to 160 therms in our old house.
08 Oct 2008 08:03 PM
Posted By 183eej on 10/08/2008 4:22 PM
... I'll have to email it to you.
... I noticed in the bottom right corner it indicated TXU copyrighted it in 2007.  This tells me this program was around when you and I both installed our systems.  ... if you get into this and figure out we can squeeze a check out of these folks, please let me know and I'll sing at your next wedding for no charge.
Dale, I got it - thanks!
I also noticed the 2007 Copyright.  I'll look into this.  If there's applicability to me (and you) I may have to switch from being a Cirro customer back to being a TXU customer.
Thanks for the offer to sing!  (Won't be needed!)
08 Oct 2008 08:13 PM
Posted By Brock on 10/08/2008 5:42 PM
My residence is electric and NG.  Gas for HWHs, dryer, cook top, pool heater, and outside cooking grill.
I did not turn on and leave on my DSH until just a few weeks ago.  So, for now, it's still an apples-to-apples comparison, but, in the future there will be a savings from NG usage reduction to the HWH gas burner.
I'm in the process of setting up WEL instrumentation to provide long-term data on the portion of total KBTU the HWH receives just from the DSH.
(During this 'shoulder' season here in Dallas at the moment, between Summer and Winter, the DSH isn't doing much.  So far this month (Oct.) only 5% of the HWH's total KBTUs consumed (from NG burner + DSH water) is from the DSH.  Not unexpected though.  Will be interesting to see the data long term.  HWH has a 40,000 BTU/hr burner.)
TechGromitUser is Offline
09 Oct 2008 01:31 PM
Another thing to consider it the life expectance of the systems. Even if the cheaper an ASPH has the same COP's as GSHP, the GSHP would still be a better investment given that ASPH generally only last 10 years and GSHP lasts at least twice as long with lower maintence costs.  Given the system Effiencency rating for heating and cooling, the life expectancy of the system, lower maintanence costs and now a 2k tax write off, Geo is a No brainer.
RichardUser is Offline
16 Oct 2008 11:00 AM
This is really great news! I've been checking NYSERDA for tax incentives for geothermal heating systems and till today, found nothing. If this is true, I can't wait to complete my tax forms! We're installing a geothermal heating system even as I am typing this response.
16 Oct 2008 05:25 PM
On the tax credit now, reading something on it leads me to believe that the installing contractor, such as Joe, qualifies for up to $1,000 tax credit for every system retro-fitted. What do you guys know about this?
People Online People Online: Visitors Visitors: 337 Members Members: 0 Total Total: 337
