Posted By tuffluckdriller on 02/20/2009 11:23 PM
dmaceld,
Did you insulate the floor in that crawl? How are your bills? How is the comfort? Does it distribute evenly enough? And do you use any cooling?
The crawl walls are ICF. I put 2" XPS on the inside of the footers and 3/4" XPS under a rat slab throughout the entire crawl space area. I will have to play with the distribution more after we finish building and move in, but so far, for working, it's comfortable throughout the whole house. Since Christmas I've been running my pellet stove mostly in order to use up the ton of pellets that came as part of the stove deal. The air handler runs constantly so air is circulating through the whole house. Interestingly, I do have an issue with air movement past the thermostat in the hallway, it's almost nil! The living room gets up to 72+ before the thermostat hits 70 and turns the stove off. And with the pellet stove heat the master bedroom is a couple of degrees cooler than the living room. But once I switch back to the heat pump as primary heat source I expect to see a more uniform temperature level throughout the house. With the pellet stove heat the floor is only about 2 - 4° cooler than the room air.
The return air enters the attic through registers in the ceiling and then is drawn down into the air handler from the attic.
I haven't used cooling yet. I hope my ERV will take care of a good share of the summer cooling load. It's in the attic and dumps into the return air plenum there. Based on a few warm days in November I may have to run the ERV for cooling any time the outdoor temp is above 50F!!!
From Christmas to now, about 58 days, I've used about 1200 lbs of pellets. That's about 20 lbs/day. At $250 per ton that's about $2.50 per day and about 160 - 170k Btus/day. Temps have ranged mostly from about 20F to 35F in that time.
