slenzen
cmkavala
| 09 Mar 2009 10:23 AM |
Posted By Brawler on 03/09/2009 9:38 AM Amazing how any thread, no matter how specifically the question is worded ( read the original post) can be "guided' by ICF contractors. Usually I am accused of making it a steel sip thing |
fwriepe
| 20 Mar 2009 10:33 AM |
I have patented a new building system that is now under development but not yet on the market. It is called system-5-aac and is a marriage of aac with stick framing composite with high-density injected urethane foam. The finished wall is 9" thick with an R-33. The system has no thermal bridging, is fire-proof, insect-proof, zero maintenance, no air infiltration or vapor transmission, has high shear strength and uses half the wood of conventional construction with no sheathing. It is an excellent acoustic barrier, allows electrical installations to be even easier than in conventional framing. There are no voc transmissions and there is very little waste. All components are assembled on site with ordinary tools and no hoisting equipment. All normal interior finish systems may be applied. I think this system will soon become a popular green system in the US and Canada. It will qualify for LEED credits.
Frank W. Riepe, AIA |
Alton
| 20 Mar 2009 12:00 PM |
Mr. Riepe,
Please put me on your mailing list for all info on this new building system. My e-mail address is below. I am into new building technologies and at times I have clients that want the latest and best. I hope to see this new system at a trade show soon. |
fwriepe
| 20 Mar 2009 12:05 PM |
Thank you for your interest. One correction: the system is patent pending. |
ErgoDesk
| 20 Mar 2009 09:21 PM |
Mr. Riepe,
Please don't put me on your list, PU is bad for everyone involved. |
| Build Smarter with Structural Insulated Air<br>http://StyroHomeNews.blogspot.com |
ErgoDesk
| 20 Mar 2009 09:30 PM |
One thing I can see being a problem is that so Dude will put Vinyl PVC Siding on this sucker and burn themselves down. |
ErgoDesk
| 20 Mar 2009 09:39 PM |
I feel the same way, but there are NO ICF's here,
http://tinyurl.com/NoICFsHere
toddm
| 21 Mar 2009 08:42 AM |
Mr. Riepe, I briefly investigated veneering systems developed in New Zealand and Australia to clad stud walls with 2" AAC panels. I decided that there is no DIY substitute for the channels and other special joinery they use to control expansion and contraction. www.celcrete.net/downloads/Celcrete2006PDFmanual.pdf How does your system address this issue?
softfoma
| 21 Mar 2009 10:32 AM |
As a professional insulation contractor I would recommend the use of celulose. I often findthe product in existing homes. In wall cavitries it seatles andleaves gaps in the tops ofthe cavity. In ceiling use where itis blown in,in timecreates a terriblehouse dust prolem. Those contractors who do this will tell you this does't happen with the wet spray binder however I've tasted the pudding and it isn'tgood. If you can use foam do so, especially closedcell as those panels. You get benefits you won't get with the others. You can also forget about a vapor barrier, it is one. |
fwriepe
| 21 Mar 2009 01:10 PM |
toddm:
The proposed system is distinctly different from the Celcrete system in its installation and insulation. It does have specialized components that cannot be improvised. That said, special equipment and skills are not needed except for the closed-cell injected insulation. I hope to bring it to market at the end of this year. |
