Posted By bmancanfly on 05/06/2009 6:29 AM
Posted By mac31313 on 04/01/2009 5:54 PM
yes,
nail the fir strip to the concrete (on top of rmax) with 2 3/4"case hard nails,
you can tack rmax in place with small blocks or glue, seal joints, then add fir strips
mac
I think I'll be doing it the way you suggested.
When you say seal the joints , do you mean with tape?
tape will work,
but i use foam in a can ....get the pro style(reusable gun with control...less mess)
seal to floor,between sheets as you go.... 1/4" bead
also foam around outlet and switch boxes, penetrations, doors and windows
mac
