Posted By Caluwe-Gong on 12/12/2009 5:23 PM
Dear Gareth,
Does this house of yours has gutters and proper installed down spouts? You write in one of your last sentences that ... everytime it rains or snows ... . And you also tell us that the water table is 18" below your basement floor. So it looks that a proper way of directing the rainwater will solve the problem.
Maybe i missed something.
Thank you for your thoughts
Caluwe-Gong, but yes we have ensured all the downspouts discharge 10-20 feet away from the house as well as placed a membrane around the first 3 feet of the house on the north (side) and east (front of the house under the bay windows) the move - it would appear that the leaks primarily occur at the front and back under the bay windows and under the deck. There is popcorn like concrete the top 6 inches and bottom six inches of the wall and when we removed the foam on the inside their is the smell of earth and some dirt sitting on the footing that is wet to moist. We recently observed a leak coming from the 6 inch top of the wall (above grade) along a two inch hole next to a plastic tie anddripping down the foam and coming out then running along one of the plastic ties the previous home owners had installed drywall over - we will be removing all the drywall in the basement and replacing it with the anti mold drywall or cellulose free once we figure out how to do deal with the water issue and how it is getting in.
At the bottom we are thinking we do may not have a complete seal down there or improper weeping tiles and drainage and may be removing all the soil around the house in the spring redoing the water proofing but we have had water proofers telling us to remove all the foam on the outside and then park ( but how does one parge over the plastic - will it not need to be all cut then once again will it not expand or contract different then the parge and cause cracking. They will will wrap the house in an aquaseal and dimple membrane and back fill with clearstone with a membrane over the clear stone. Others have told us to aquaseal the foam then just dimple over it - but I have read in doing that it is said that any water that gets has no way to get out.
Another has said put an internal weeping tile inside and one outside and then will capture both but then we are also looking $$$$$$.
I think there may be too issues - one at the bottom of the walls and one at the top. The bottom may be no hydraulic break with the shallow water table and capilary action bringing water up the footings to the foam and sitting there since the basement floor does not connect to the wall just sits on the footing and connects to the foam. We may need to break apart this sections and remove the foam up the wall 10--20 inches and put some dimple board (the water prooffing board with internal weeping tiles) then connect all that to the sump pump.
The one at the top of the wall I think may be the brick surfacing sitting ontop of the popcorn top six inches of concrete that sits upon the solid wall from what we have seen. This pop corn is covered by a cracking parge or stucco coat and I think driving rain or water is getting into the brick dripping down and entering that way or coming in next to the wall as it runs down the bricks hits these cracks and moves into the house that way throught he foam.
We have also had an issue with carpenter ants in the exact same areas that we are having a water issue and think they are related to the deck in the back until they showed up under the front bay window inside and coming out of the water clearout at the parge/stucco brick interface ont he outside wall.
I will provide some pictures tommorow - I do appreciate any support anyone can give us to solve this while keeping our costs down as this was our first home and we thought we were buying a perfect finished home until these issues started. We also tried to right to Holmes on Holmes one month after we moved in and realized our (home inspector did not really inspect or to be fair have time to inspect - he was only given 3 hours) but did not get a reply back Holmes. I appreciate the time and effort anyone puts into their responses here.
It would appear those we have talked to in the area do not have a lot of familiarity with leaking ICF or what to do with it or are applying their expertise for water proofing/basements using other construction methods instead of researching icf and looking for answers in what they see when they come here.
Writing that I see pictures will help I will go take some today and post them tommorow.
