thagreen
27 Jan 2011 08:43 AM |
Abu, I'm also in the Ottawa region and have built in the past years. Here are some names of contractors which I had to price out the blocks and install. Robro Construction, Upper Canada Building Services. I'll try and dig out their contact info. I do beleive they'll take on the whole project or can take care of the structural only. I found pricing was competetive. Send a private message if your interested. |
Abu Yusuf
27 Jan 2011 08:44 AM |
Eric, we are at the preliminary stage trying to estimate the cost of building. If we go ahead, it will most likely be located west south-west of ottawa. We are currently considering a lot that is located south west of Stittsville. |
Abu Yusuf
27 Jan 2011 09:22 AM |
Hi,
I would be interested for sure, I got Robro construction contact information from the EMM. How did your construction go? Would you do it again? One thing (well, there're more than one) that's not clear to me, is with no studs, how do you hang stuff on the walls? Any suggestions with how to proceed with ICF construction are much appreciated.
thanks,
thagreen
28 Jan 2011 04:48 PM |
Went very well. I'd do it again anytime(if she lets me). There are studs present from top to bottom which can be found with a stud finder with depth adjustment (ones with no depth still find it with multiple pass and sometimes just one). Just build it and enjoy the benefits aftewards! Good luck and let me know how the process is going. Cheers!! |
thagreen
03 Feb 2011 01:52 PM |
Abu, found the info for UCBS which are in your area. Here it is 613 223 2894, 613 537 8782. Let me know if contact info don't work. Cheers! |
