I do appreciate your opinion and the link to the report from a few posts back.
I contributed 15 Texas houses to the recent MIT study. MIT reported ICF buildings to be 20% more efficient than conventional. I believe this 20% better number is low (at least for Texas).
Why? (1) Many of our customers regularly communicate their utility bills. (2) I’ve lived in an ICF home for several years myself and know approximately what neighbors are paying and (3) About half of the Texas ICF houses contributed were built with conventional BAT attics.
All 15 Texas homes I provided to the study had sealed foam attics. Why? Because as most of you know, ICF is not ‘nearly’ as effective without taking the attic or roof into consideration. Imagine a screen door on a submarine.
I believe mixing these different ICF construction approaches knocked the final data down to 20%.
Regarding the link provided to the ORNL report from ten years or so ago. Why does the ORNL report say that ICF performs less than half to one third as well as the 20% just reported by MIT?
1st this ORNL report is actually a compilation of several reports and if you’re not careful you might read a section and think it’s talking about another area of interest. For example directly from the report:
“The steady state R-value traditionally used to measure energy performance does not accurately reflect the dynamic thermal behavior of massive building envelope systems. “
And they continue…
“Since the majority of U.S. residential buildings are built using light-weight wood-framing technologies, all energy performance comparisons in this paper are made against light-weight wood-framing buildings. “
Clearly, this report is a compilation of several reports…
“An overview of several historic and current U.S. field experiments are discussed. These experiments were performed in a wide range of U.S. climates utilizing several building sizes and shapes. Theoretical energy performance analysis is presented for a series of four wall assemblies. “
Is the report now talking about ICF and the other three mass walls types at this point? No.
“Burch built four one-room test huts at the National Institute of Standards and Technology (NIST) to compare seasonal energy performance of wood-framed, masonry, and log construction.”
“It was observed and documented that heating and cooling energy in massive houses can be far lower than those in similar buildings constructed using light-weight wall technologies”
At this point they’re still talking about wood-framed vs. mass.
Often misquoted, the portion about Burch’s research says: “Significant energy savings were noted for the house with a higher internal thermal mass”. Are we talking about the four theoretical mass walls at this point? Any type of ICF? No, although this statement establishes the superiority of mass walls we are not yet talking about internal and external mass just mass versus low-mass.
The report continues:
“Robertson and Christian investigated eight one-room test buildings that were constructed in the desert near Santa Fe, New Mexico, to determine the influence of thermal mass in exterior walls. The buildings were identical except for the walls (adobe, concrete masonry, wood framed, and log)”.
So ICF wasn’t included in part of this part of the study? No. It wasn’t. The section on Robertson and Christian continues…
“This study demonstrated that on small windowless massive test huts, energy consumption can be up to 5% lower than in a light-weight building. It is important to point out that during this study, the massive walls had about three to four times lower R-value than the wood walls (wood-framed wall R-value was about R-13 vs. R2 to R5 for adobe, concrete masonry, and log walls)”.
Just in case you missed that, the report continues…
“This gives a completely different meaning to the 5% energy savings that were reported.”
One might make the claim correctly at this point the internal mass is better but the report is talking about adob, concrete masonry and log walls, not ICF (not yet). At this point we’re still taking about adobe, concrete masonry and log walls compared to wood-frame.
Then the report discusses the 1999 NAHB study: “This suggests that most likely thermal mass related energy savings during the NAHB ICF study were in the neighborhood of 11%.
MOST LIKELY? Interesting? The report continues:
“Masonry or concrete walls having a mass greater than or equal to 30 lbs/ft2 and solid wood walls having a mass greater than or equal to 20 lbs/ft2 are defined by the model energy code [MEC-1995, Christian 1991] as massive walls. “
What? Solid wood wall that has mass of 20 lbs/ft2 is considered a mass wall by this study?
“They have heat capacities equal to or exceeding (6 BTU/ft2 F). The same classification is used for this work.”
This is a very low heat capacity to define a mass wall since the average density of concrete is 133 lbs/ft2 with a heat capacity of well over (20 BTU / ft2 F).
Regarding ORNLs BTC 1995 Dynamic Benefit for massive systems model (DBMS). According to the report: “DBMS should be used only as an answer to the question: What wall R-value should a house with wood frame walls have to obtain the same space heating and cooling energy consumption as a similar house containing massive walls?”
There is some groundbreaking work here but putting it into one mixing bowl has confused the intent of the research and causes many to misquote it. And folks continue to misquote the report. Take Bakersfield (figure 7), for example, sometimes used to say that the report says you only get a 10% improvement with ICF over conventional construction. What this chart actually says is that you will get a 10% savings with ICF over a conventional wall built to R-25. Not too many walls are conventionally built to R-25. Furthermore, regarding mass, if 15% of the density of concrete is considered a mass wall by the report what might we learn if we did a study with a higher standard for a mass wall? Put another way, how much better is ICF if you use a mass value of 130 lbs/ft2 – 140 lbs/ft2 and then compare it to today’s actual conventional construction of R-13?
Remember the computer simulation for the four different mass wall types including ICF used the same mass and the same R-value for each. My hats off to galore as he did not miss this point at all and built a custom system that exceeds what’s presented in the report.
The last statement in this report implies that the report was much more about ICF than most of its content and says: “It was found that for ten U.S. locations, ICF walls … the average potential whole building energy savings (ICF house vs. conventional wood-frame house) can be between 6 an 8%”.
MIT came up with a huge difference in favor of ICF and I believe it too is low. If you doubt it, just ask a neighbor living in an ICF home. Regards.
