DEAR FORUM MEMBERS:
PLEASE BE ADVISED OUR MgO CORP's INNOVA SIP's HOME KITS ARE NOW AVAILABLE FOR EXPORT GLOBALLY: EX Miami Florida
We can supply direct from MgO Corp USA's Partner Factory.............. Raw Panels as well as fully supplied custom panels to suit your projects design............ needs........... EVERYTHING YOU NEED to OWNER BUILD WILL BE DELIVERED STRAIGHT to SITE ANYWHERE IN THE WORLD (Minimum order qty by 20ft container loading) Indicative Pricing as follows:
We can provide blank SIPS panels in standard lengths to you or we can fabricate the panels into building kits per you plan.
INNOVA manufacture three types of SIPS panels:
OSB SIPS
MGO SIPS (magnesium Oxide SIPS)
CSIPS (Cement Fiber SIPS)
Each of these panels are manufactured in a variety of lengths and thickness.
Below we have listed some standard size panels for your review:
4" thick MGO CORP BOARD SIPS with 10mm skins USD$5.00 sf (panels available in 4' wide by 8' and 10' tall) 4" CSIPS with 5/16" James Hardie Cement Fiber board skins: USD$5.00 sf (Panels available in 4 foot wide by 8',10' and 12'** tall panels) (** 12' panels are special order and have additional lead time) 6" OSB SIPS with 7/16"GP skins USD$6.00 (panels are 4' wide and up to 24' long) 8" OSB SIPS with 7/16" GP skins USD$7.00 (Panels are 4' wide and up to 24' long)
All of the above panels are manufactured with 1#density EPS foam.
The Foam we use is non-flammable, non-toxic and is treated with borate for termites. For 2# foam, add USD$1 sf to each of the above prices.
All prices include crating and loading in your container for export.
Wall panels have electrical chases at 15" AFF and all roof panels have chases at 2' (center of panel)
Please let us know how we can be of assistance to you,
Best Regards: Steve Marskell (General Manager) email:
[email protected]
