Donaldson, to each his own. No one ever said concrete should not be reinforced. In fact ICF can be reinforced to three seismic strengths: C, D1, & D2. To my knowledge SIP can only be built to Seismic C under the IBC. An ICF structure can (and has) been built up to 9 stories. It is solid rock, after all. And it has the strength for concrete inter-floor decks and a rooftop concrete patio.
As to the completely enclosed envelope, apparently most builders where you are, are doing it wrong. Over the walls should be steel trusses, with cementicious sheathing and fiber-cement shingles or tiles. Then in the rafters on the underside of the sheathing should be sprayed expanding foam, preferably soy-based ('insoylation'), all the way down to the walls. This adds rigidity to the roof, glues it to the walls, and seals the attic as conditioned space. Airtight. Same can be done with SIPs.
coddave, WRT fire, I want non-combustible. Period. No, we cannot buy concrete furniture or steel toys, but we do the best we can, don't we? A non-combustible structure should be the goal, and in the event of fire a structurally-sound building should remain, and the ability to -replace- damaged foam is vital. These are not the case with SIP.
slanzen, true, thermal mass shines best when outside temps make wide swings during the day. When the weather is continually cold, it will eventially permeate halfway through the concrete and start absorbing heat from inside, albeit very slowly. Even so, check this out:
LINKcmkavala, interesting study. For example:
Some foam plastic insulation materials use blowing agents that have a high resistance to heat flow causing the insulation to have an abnormally high R-Value at the time of manufacture. It is now known that these blowing agents diffuse from the cellular structure of the foam until a level of equilibrium is reach many years after it is manufactured. As the high R-Value gases diffuse out of the cellular structure, the ability of the insulation to prevent thermal flow is reduced, losing up to 30 percent of its original insulating ability. EPS foam does not use these types of blowing agents, therefore, its insulation performance remains stable over its entire life.
"If you compare EPS side-by-side with some foam plastic insulation materials right after they are manufactured, the other materials may have a higher R-Value," said de Campos. "But EPS is stable and does not experience any thermal drift and does not lose R-Value over its life. In the long run, the thermal performance of EPS insulation is constant, and when all cost and performance factors are considered, it typically provides the greatest insulating value available."
Meaning, when SIP isocyanurate insulation is first blown it tests high insulative value, but then as it offgasses (formaldehyde), the insulative value constantly declines. And the study makes clear that ICF's EPS does not do this, and maintains its insulative value over the lifetime of the home.
PanelCrafters, that Oak Ridge study proves the benefit of the thermal inertia of concrete, even -with- the inside insulation of ICF:
A 20% difference was noticed between the ICF house and the conventional wood-framed house’s energy consumption. In the final report, NHAB researches concluded that this 20% difference was caused by the R-7 difference in wall R-values ( ICF wall R-value was about R-20, conventional 2x4 wood stud wall R-value was about R-13). However, simulation data developed by ORNL for a similar 121m2 (1300 ft2) one story house suggests that for the same climate a difference between R-20 and R-13 should yield a maximum 8 to 9% difference in annual whole building energy consumption. This suggests that most likely thermal mass related energy savings during the NAHB ICF study were in the neighborhood of 11%.
chuck07, please read that Oak Ridge study. You are just guessing about thermal mass. And who said ICF gives only benefit because it is sealed? I didn't. Where did you get that?
And who said ICF should be built with no reinforcement? I didn't. Quite the contrary to what you think I said. And who said ICF can be built in the same time as SIP? I didn't. Where did you get that?
No, it is true that ICF takes longer to build. And it is true that it takes a higher skill level. But it is also true that it insulates better, is far stronger than SIP, is non-combustible, and will last 1,000 years.
That is my takeaway from this.
