Posted By cmkavala on 08/03/2008 7:59 PM
Fish wires, that sounds easy as a remodeling job.
Please explain how easy it is to add a switch and/ or receptacle after the drywall is finished?
And, how often must a box be added after the home is finished? And, are you trying to say, that it's impossible? "Agony"?
1-1/2" furring strips not only provide a clear electrical chase for future work, they provide for less sound transmision and additional insulation
There is
no advantage when it's an added cost. It's not an additional cost with traditional OSB SIPS.
Are you saying there is no upcharge to fish wires? and you use more wire because you can't change direction wherever you want - you have to follow the chases.
Heaven forbid if you want to add a recept. where there is not a chase, then what.....another remodel job?
Tin Man, your arguments are extremely weak. I really enjoy your attempts to justify the extra costs that your Tin SIPS require, but as they say, "They Don't Pencil".
