American Polysteel
Find a Green Building Pro
Browse Project Albums
View Product Guide
Forums > Green Building Technologies > Radiant Heating > Subject: water to air radiator
gordUser is Offline
08/26/2008 3:21 PM
1100 sq feet garage. i am looking for an economical way to get the heat from the water into my garage. not going to install slab lines but a heat exchanger. where do i look for teh good ones. one with a fan i would think?
gregjUser is Offline
08/27/2008 3:17 PM
I'm not sure I understand what what you are asking. Do you already have hydronic heat in the house? What temp? Is your heat source of sufficient capacity to handle the added load?
gordUser is Offline
08/27/2008 3:19 PM
yes, the system was designed with this heat load included. the unit is a 5 ton genesis water to water system. i will have storage system in house and plan to run loop to garage to heat it. i thought a rad / fan system would make the most sense. i have not looked at any yet though.
BrockUser is Offline
08/28/2008 12:10 PM
We have a couple of those here at work. Basically they just have a thermostat that opens a water valve at whatever it is set for and then a sensor close to the coil that kicks on a fan when it gets hot. They just run hot water through it. I have seen similar home made things using old car radiators with the attached 12v cooling fans, basically right out of a car. I don’t know where to get the professional ones, I have thought about using one of them on my incoming water line in summer, but never got around to actually finding one.
Green Bay, WI. - geothermal heated indoor pool with a small solar setup
radiantbarrierUser is Offline
08/28/2008 12:22 PM
I can get the water to air exchangers as well as insulated conduit pipe to use. please see our green cooling and heating store at www.GreenInsulationProducts.com for more info or call 877 904 8424
08/28/2008 4:55 PM
I don't see any exhangers on your site? Did I miss them somehow?
Professionals Serving
Your Location:
Sierra SIPs (San Andreas, CA)
View More
GBT Project Albums:
efficiency (Old Town, ME)
Off-the-grid home (E of Eganville, ON)
Jay's House (Burlington, VT)
MN Geothermal Retrofit (Twin Cities, MN)
Kitchen/gathering room (Manchester, MI)
More Info |  Search
