Greetings,
I have a very novice question on radiant floor heating.
About 1/3 of the flooring on the first floor in my house (Chicago suburbs) is ceramic tiles, which includes kitchen, bathroom and a hall area. The problem is the following: while we keep the house fairly warm (68C during the day), the ceramic floors are very uncomfortable during winter months. We also have a single-thermostat for central AC, which makes it challenging to keep an even temperature throughout the house.
While in a perfect world I'd love to install a really green solution with GSHP... that doesn't seem possible in today's economic environment. Thus I was thinking about a high efficiency water heater that can support radiant flooring (something like AO Smith Vertex 100) and a simple staple-up solution to keep the ceramic portions of the floor warm. We have a full unfinished basement in the house (it is unheated, but gets fairly warm due to open ductwork + water heater + furnace being there), so the access should be fairly simple.
I am NOT looking for the heated floors to replace the existing furnace, which does a fairly decent job keeping our house warm - instead I am looking for an auxiliary solution to (1) make the floors more comfortable and (2) assist with more even heat distribution between the first and second floor in the house.
I came across several possible options:
- Onix staple-up
- PEX Staple-up with heat transfer plate
- PEX suspended
- PEX Suspended with UltraFin
- PEX attached to joists
There seems to be many opinions about pros and cons of each, including too localized heating with heat transfer plates (people feeling exactly where the joists are) and concerns about Onix costs.
Any help / advice / recommendation you can provide will be greatly appreciated.
Nick
