Where to buy Geo Horiz Ground Loop Tubing?
Last Post 05 Aug 2007 09:47 AM by geodean. 4 Replies.
zootjeffUser is Offline
04 Aug 2007 08:42 PM
If your going to do a DIY geo tubing install, where would you buy the tubing?
Also what diameter do people typically use?
04 Aug 2007 09:25 PM
Where do you live? You are looking for HDPE pipe. http://www.isco-pipe.com/ is where we buy ours.
Typical sizes are 3/4" and 1"
04 Aug 2007 09:43 PM
a few things to consider:
HDPE joints need to be fused with special equipment
If you have multiple circuits, they need to header into a "reverse return " manifold to insure equal flow to each circuit.
After the ground loop is built, you will need a high volume, high pressure pump to purge all of the air out of the system.
The loop circulating pump needs to be sized for the loop so that you get 3 gpm flow.
good luck with  your project
04 Aug 2007 11:37 PM
I live in Portland OR.
Is it the same as uponor wirsbo crosslinked polyeth?   I have the tool that expands the wirsbo so that you can plug a plastic or brass fitting into it. You also need a little ring when using the wirsbo. The tool I have will do 1/4 1/2 3/4 and 1 inch diameters..
How do you order the pipe from http://www.isco-pipe.com/? do they have a page to order or do you need to call for a quote?
-Jeff
crosslinked poly is known as PEX which is not the same as HDPE pipe.  With pex, you crimp the joints.  With HDPE, you fuse the joints.   See here
ISCO pipe has an phone number :   Please call 1-800-345-ISCO, send us an e-mail at [email protected], or contact the office below.
If you are determined to do this your self,  you should check out this site.
I am not recommending that you do this,  just making you aware of the option.
People Online People Online: Visitors Visitors: 141 Members Members: 0 Total Total: 141
