davar
| 14 Jun 2008 09:44 PM |
Hello. When I went to start my waterfurnace premier for the first time in a month, nothing happened and the status light is blinking.I shut off the breaker and turned it on again and it does the same.Anyone got an idea of the problem? I will call the service center Monday but just wondered whats wrong.Thanks
engineer
| 14 Jun 2008 10:51 PM |
Satus light blinking is normal for my Envision. Envision is closely related to Premier. My guess is your unit is not getting "calls" from thermostat or zone controller
fsq4cw
| 15 Jun 2008 01:27 AM |
Before you call for service, do the logical things, like check or replace your air filter, vacuum the air heat exchanger & clean your condensate drain.
SR
engineer
| 15 Jun 2008 09:32 AM |
Those suggestions are all good but none of them will cause a unit not running to run |
TRI-L
| 16 Jun 2008 01:45 PM |
IF you have Internet access LOL. Go to Waterfurnace.com and down load owners manual, go to page 35. |
