The comments and suggestions here, from all of you, are very much appreciated.
My conclusions is that it's reasonable to expect some economies of scale with respect to an HVAC professional doing 5 geothermal vertical closed-loop installations that are similar in size, common equipment supplier, common material suppliers, single driller, etc. How competitive the market is, though, that's managing current margins, will manage how much of a discount results for the increased volume of work in the same location (5 lots contiguous to each other).
My conclusion also is that it's not a winning strategy to put in a common loop. Little possibility of economy of scale (still have to drill all of the wells), a loop problem putting multiple property owners out of commission at the same time, and ownership/responsibility challenge all appear to present significant challenge to a common loop being a winning strategy.
Thanks for the open-loop design suggestion. This isn't a feasible design option for this location, unfortunately.
A parenthetical conclusion is that these conclusions may not hold if the volumes move from five contiguous lots to a multiple hundred lot subdivision.
A big thanks for such great helpfulness!
