Hello this will be my first post! I've been trying to find this for over a week now and if someone know of a posting for it I'd love a link.
I'm interested in building a house in the Tampa area using 2 thermal masses (2ft X 8ft X 24ft with a 4ft X 7ft door) to heat and cool the home. Cooling is a much larger concern to me given that I live in Florida. The house is going to be roughly 2500sq ft. I intend to us 2X6 outside walls and passive solar designs for heating/cooling optimazation. I've also been thinking about setting up some kind of canopy/canvas as a second roof so I won't have as much radiant heat hitting the house during the cooling periods. The 2 thermal masses I intend to use will be simaliar to
Build it for Solar walls, but I intend to put tubing inside the walls so I can both heat and cool the thermal masses with liquid. For heating the masses and water I'm going to use solar water panels. For cooling I'm going to use a Horzontal closed ground loop. I intend to have roughly 1500ft of pipe buried at 9 - 11ft depth.
Ground Tempatures and
Ground temp variations made me decide to go a bit deeper than 3 - 6ft with the pipes. That being said I really like
DIY ground loop cooling system idea this guy has. I've been thinking about installing it in such a way as to be able to convert it over to a heat pump system if it doens't work. Just make it so I have access to everything in the basement so I can change over if I want to.
I'm very handy but in the end I may break down and use a contractor if I can find one who'll work with what I want for a low price in Tampa area. (ya good luck right? hehe)
Anyway I'd love to hear what you think of my idea,
Mark
