willy
| 04 May 2009 05:55 AM |
Is there a problem using a split tranquility 27 system with a high velocity air handler? I've been told on a project that this combination won't work in the heating mode. |
joe.ami
| 04 May 2009 08:07 AM |
Have not done it myself, but have heard positive feedback on such systems. Is the HV system already in place? j |
tuffluckdriller
| 07 May 2009 10:29 AM |
Just be sure that guidelines are followed for the HV system. You should require at least 8 supply outlets per ton. Also, expect the efficiency to take about an 18%-22% hit. Capacity will also take the same amount of hit. This means that if you had a normal duct system and required 4 tons, then a high velocity system will likely require 5 tons. I'm not posting this as an expert on this subject, but these are some things I've learned lately from a dealer with experience trying to fix problems... |
| Clark Timothy ([email protected])<br>Geothermal Heat Pumps: Heating and Cooling that's Dirt Cheap!<br>www.pinksgeothermal.com |
engineer
| 07 May 2009 07:53 PM |
I'll bet placement of outlets is more critical in HV owing to possibility of uncomfortable drafts |
tuffluckdriller
| 08 May 2009 12:52 PM |
Placement is a huge part of it, too. The two biggest complaints I've heard of are: 1. NOISE 2. NOISE |
Blueridgecompany.com
| 09 May 2009 09:31 AM |
We distribute Hi-V and have a install manual posted on line, It provides guide lines for out let numbers related to the different models. Some of the key points are that there are minimum and maximum outlets for each size unit (50,000, 75,000 & 100,000 BTU. For cooling you want maximum out lets, heat can be minimum recommended outlets. To avoid noise/sound use maximum. It is a fairly easy install and used with a chiller or Geo system you can have multiple air handlers off one tank. further you do not have the conventional limitations of compressor line sets. I have never heard of reducing out put the Hi-V by 20% for cooling. Maximum outlets is the key. Outlets can be on the floor, wall or cealing. The area of air turbidity is about 18 diameter by 4 feet. Avoid placing outlets over/under curtains and places where there will be chairs/couches. There is some advantages with Hi-v, they offer a great filter, outside air is easy or you can place an air to air recovery in line on the return. Good luck, Dan |
| Dan <br>BlueRidgeCompany.com |
willy
| 10 May 2009 06:32 AM |
Thanks for your ideas, I will count the outlets. Dont think it is near 8 per ton. I get the feeling also there may be something about this split system in particular that manufacturer may be having heating problems with? |
| 10 May 2009 08:15 AM |
The heat pump has no knowledge of what happens downstream of it. So if the flow rate is correct, you can use any pressure you want (until the noise bothers you).
| 10 May 2009 12:02 PM |
This may help, here is a link to the plenum sizing and outlet requirements of the HI- V 50, 70, 100, 140 http://www.blueridgecompany.com/image/view/64 Dan |
joe.ami
| 10 May 2009 03:53 PM |
Dan, Are you discussing HV with hydronic or DX coils? The unit mentioned above would use a DX coil. J |
| 11 May 2009 08:44 AM |
Joe, HI-V is designed for a few coil types, here is a couple links for alternate coils, there outlet and plenum size is a constant. There is also a good copy of the install manual on our site, it is help full in understanding the system ducting and options. have a good week, Dan
http://www.blueridgecompany.com/radiant/hydronic/271/esp-water-coil-modules http://www.blueridgecompany.com/radiant/hydronic/116/esp-cooling-and-coil-modules
joe.ami
| 11 May 2009 09:03 AM |
I get that it can work either way, but you seem to be discussing hydronic application. The Tranquility 27 mentioned by the author of this thread would require a DX coil in the air handler. j |
| 11 May 2009 11:42 AM |
J, The RPM-E TX is the same as the DX , I clarified that just now with the rep, You need to chose between R- 22 or R-410 A,This is done at time of purchase. Dan
joe.ami
| 11 May 2009 09:58 PM |
K dan, appreciate your enthusiasm for your product, but you spoke of chillers and storage tanks...sounds like hydronic coils. J |
| 12 May 2009 08:08 AM |
J The HI-V offer coils for multiple applications, Water or compressor systems, here try this link; http://www.blueridgecompany.com/hydronic/forced-air/energy-saving-products/5 This will give you the line up of most of there product in category. They even offer a very good quality air filter system, it is a private label Sun Pure unit with custom flange to adapt directly to there box. Dan |
joe.ami
| 12 May 2009 08:40 AM |
Not to belabor the point but the thread had a specific question so I'm trying to clarify our answers.
Posted By Blueridge company on 05/09/2009 9:31 AM For cooling you want maximum out lets, heat can be minimum recommended outlets. In water to air geo however, heating is a refrigeration process just like cooling and requires the same CFM. No reduction of openings would be recommended for heating.
Chiller system however would use water to water geo currently not qualified for the tax credits. I have never heard of reducing out put the Hi-V by 20% for cooling.
It's hard to beat 1000 sq" of fan coil at any speed. j
