Thanks for the info. So essentially you are trying to match up the head loss of your pump(s) to the head loss in your loop field??
Also... as far as I know pumps generally only come in one size. Say I run across a loop field that requires 25% more than one pump can handle. I then have to get two pumps and I am guessing that a great deal of efficiency is lost. Should I be cognizant of this when designing my loop field.
