This thread has spawned from the Due Diligence thread. I have received three geo quotes and they all very greatly in price. Maybe it was lack of information I gave to the person giving the quote, maybe it was lack of geo knowledge, maybe it was a lack of sips envelope knowledge or maybe any combination of all of them. Here are a few of the specifics about the house:
2750 sq ft on main and upper levels
1385 sq ft in unfinished walkout basement- planned for hydronic radiant heat
1385 sq ft in attached garage- planned for hydronic radiant heat
The walls will be constructed of 6 1/2" eps sips panels on the main level, upper level and garage. The basement will use 8 5/8" eps sips panels below grade. The roof will have conventional trusses with spray foam and blown-in insulation above that. I plan to use taller sips panels and hang the floor trusses from the top of the wall trying to create an unbroken barrier where the floors come together (basically no rim joists to seal off).
The property is located in central MN and the ground is primarily sand. Elevation is 950' The lot is heavily wooded with many mature trees.
The house has approximately 400 sq ft of window area with a majority of the area on the westward facing side of the house. The windows are either Marvin Integrity or Andersen 400 series low-e windows.
Below is the listing of the information I got from the 3 most recent quotes for the system. I don't quite understand why there is such a variance in the quotes.
Quote #1
If we were to do full Geothermal system. Includes all sheet metal, Wirsbo |
in floor, ventilation, Carrier 95% furnace, Water Furnace EZ 36 split, |
Water Furnace EW 60 for radiant load, all storage tanks, plumbing of |
hydronic system, and controls. Includes all material and labor for loop field |
and $ 5000.00 for excavation |
30,000.00 |
For us to supply all Equipment for Geothermal system, loop material |
and labor |
4,053.00 |
Approximate annual cost to heat, cool, and hot water for your house per |
year with conventional system. Includes heating garage |
869.00 |
year with Geothermal. Includes heating garage |
It will take about 6 years 4 months to pay for geo upgrade |
Approximatly $ 3800.00 in rebates |
Heat loss figures used for sizing and fuel costs |
107566 heating btus 31634 cooling btus |
$51,612
Quote #2
GeoComfort EZspllt Dual Capacitywith l0 year complete parts and labor warranty
GeoComfort EW water to water unit wtth 10 year complete parts and labor warranty
High foam house keeping pad
2005R Fanteck air exchanger
26-992 pump geo-link flow centers
Geo-link hose kits
100,000 bTu York modulating back up furnace for off peak electric rate.
Ducting
(30) Supply air vents
(16) return air vents
All duct woric and fittings for supply and rotum tnink lines
Two forced air zones main & lower and upper levels
Venting:
(1) Dryer vent with d.yec box to minimize space between dryer and wall.
(1) 3’ concentricvent (Iorbackupgasfurnace)
4’ bath vents, duct wort insulation and fittings (one vent for laundry room with no window)
(1)6’ hood vent, duct work insulatIon fittIngs (300 CFM or less)
(2)6’ vent, duct work insulation and fittings (For airto air exchanger)
Controls:
4 (1) Honey well IAQ total comfort control
4 (1) Honeywell IAQ touch screen t-stat with humidity, dehumidification and outdoor temp display
1000 FIeld Heat exchanger
(6)600 foot horizontal loop
(12) 300 colts SDRII.
Dirt work to header loop field
main supply and return trench up to 60’ from house
(1) Complete fill, flush, purge and antifreeze
Labor to Install the above
Gas & Piping:
All drain line from equipment to floor drain.
Geo-piping from loop field to units.
insulation of all gao lines m side building.
City mechanical permit
$36,746.00
Quote #3
Supply and install a 4 ton Heat controller forced air heat pump with desuperheater
Supply and install a 4 ton Heat controller water to water heat pump with desuperheater
Install 3 zone supply and return ductwork
Plumbing of Desuperheater to hot water tank (water tank by others)
Installation of ductwork for bath fans and clothes dryer
Installation of heat recovery ventilator for the home
Installation of non-pressurized flow center
Necessary plumbing of loop field to heat pump
All associated control wiring (power connections by electrician)
Price for the above mentioned work $34,900.00
Installation of 2750 square feet of in floor hydronic piping to include 2” foam with 3 zones. Installation of buffer tank, expansion tank, controls for 3 zone system, variable speed pump.
Price for hydronic installation $15,600.00
This system would require the installation of an 8 ton horizontal loop field to include the following:
Design and install a 8 ton horizontal slinky loop
Trenching, pipe installation, backfill
Run 2” header pipes into mechanical room from loop field
Flush and fill with methanol/water mix
Cost for loop field installation $12,000.00
$62,500
I apologize for the formatting but I tried to copy and paste what I could to avoid error. I probably could do much more investigation with each of the companies that are providing me quotes but I just am having a hard time with the variances of these numbers. I'm hoping someone here can help me weed through the information.
Thanks for taking time to review this.
