Try a different pellet, I had a pellet stove years ago and different manufacturers make them differently, one being moisture content in the pellet itself, this I noticed made a hugh difference in the amount and type of heat I recieved. Also the more moisture in the pellet the more often I had to clean the stove as the little air holes in the burn cup often plugged up and made burning inefficient and non productive heat.
