Quad-Lock Banner
User Name: Password:
Forums > Green Building Forums > General Forum - Residential > Subject: "Superior Walls" reversed
12/13/2008 6:15 PM
Maybe I am wrong, but I do not believe that thermal mass works very well in the deep South where the temperature does not vary very much.  However, if solar insolation is introduced to the home, then mass could be beneficial.
Kelly MooreUser is Offline
12/13/2008 9:51 PM
I am referring to the R-45 and how much can thermal mass mean to the efficency of the home than that...
Also if the home is built tight and has super insulation then why would you worry about the thermal mass???
Kelly
jmagillUser is Offline
12/14/2008 9:29 AM
Posted By Kelly Moore on 12/13/2008 9:51 PM
Kelly
The proper balance of interior thermal mass and insulation works in any climate.
Thermal mass  combined with the right use of night cooling a solar chimneys can reduce the need for air conditioning.
Who would not want to lower their electric bill?
PanelCraftersUser is Online
12/14/2008 3:40 PM
Really, only if you were trying to incorporate some Solar into the mix. Otherwise, I wouldn't expect much of a payback.
Super Insulate, seal everything well, ventilate properly, and you've done way more than most, and you'll reap the benefits.
....jc
12/14/2008 4:14 PM
"It also insulates the house from the humidity and moisture that will collect on a concrete wall. If you are using a regular heating system, It will cost you more to charge the wall then you will re coop from it."
These things might be true if the concrete wall was not insulated externally.
Find a Green Building Professional
Get Listed
Professionals Serving
Your Location:
