If I were you, I would use 2*12 I joists, cut a piece of reflective covered foam board to fit snugly between the webs and push it to where it is touching the top flanges, creating a 1.5" air space, and fill the other 10+ inches with fiberglass. You might get a bit less R-value, but you will be getting more of that heat you paid for directed up into your house. You can do the same thing with dimensional 2*12's but you will need to cut spacers by ripping pieces of 2*4 into small blocks. |
