Hi Ted,
I have some experience with Trombe walls in a house I designed, built, and lived in for four years in N.E. Wyoming. I built two walls in the house and both worked extremely well.
One of them was built of 10" concrete blocks filled with masonry sand. This wall was 10 ft. wide and two stories high. It began in the walkout basement level and extended to the ceiling of the main level of the house. There were two fixed windows 5' wide by 6' high, side by side on each level. On any sunny winter day, this wall absorbed heat so that by 8 pm it was 80deg F, making a cozy atmosphere in the living space where it was located.
The other wall was 6" thick, built of the same material as the larger one. This wall was a half-height wall located in the breakfast nook of the house. Because of the lesser thickness, this wall achieved a higher temp(90 F) earlier in the evening, right around supper time, also creating a very nice radiant heat surface.
All my design parameters were a result of info I gleaned from an old but reliable book by Edward Mazria, called the PASSIVE SOLAR ENERGY BOOK. Costs about $15 on Amazon(just checked it) and is an amazing primer for all sorts of passive solar applications, including direct gain, attached greenhouse, indirect gain including Trombe walls, and much more. This book is quite old(1972), but there is a huge amount of data, tables and rules of thumb that really do not change over time. I highly recommend you get this book, and also recommend the use of Trombe walls.
I would be happy to correspond with you if you wish. Email address:
[email protected] We could also talk using SKYPE, for example and I could even show you some fotos of the house using that medium. Let me know.
Dave
