Posted By schmausser on 08/04/2009 1:47 PM
We have window film installed and deeply regret it. We thought it would help with energy and privacy issues. Now I think the opposite is the case because it's so dark in the house now that we pretty much keep the lights on all the time maybe spending more for lighting then the savings account for. Would never do it again.
The VERY highly reflective mirror like privacy or highest 70%+ heat rejection versions cut out quite a bit more light than the lighter-duty ~50% versions- I'm not sure I'd ever go there either. But unless you're using low-efficiency lighting or have a sub-500 cooling-degree-day climate odds are pretty good it's still saving a significant amount of cooling power (and some heating well.)
A south-pitch 10 square foot skylight is like a 1000W space heater for 4 hours out of a mid-summer day, which takes 250-300W of cooling power to keep up with. With a 75% heat rejection film you cut that cooling power to under 100 watts. Are you really making up for the daylight loss with a lamp loads of over 200 watts?
If yes, you probably would have done better with a ~50% heat rejection film cutting the the peak cooling power for that skylight to under 150watts and kept the lights off. Alternatively, going with high-efficiency linear fluorescents with dimmable ballasts is roughly half the power of compact fluorescents. There are even "daylight harvesting" versions to maintain the room ambient within a reasonable range, etc.
May I ask which manufacturer/model film you went with?
