Posted By greenthumb25 on 10/19/2009 2:50 PM
Insulation R-value ratings can be misleading. Small voids
in irregular framing and gaps within the wall cavity between
fiberglass batt and framing of only 1 to 2% can lower the
effective R-value by 25 – 40%.
Conventional R-value tests measure conduction, which is
heat transfer between surfaces in direct contact. The cellular
structure of spray foam is a poor conductor of heat, which
gives rise to high R-values.
_____________________
Thats why 15" wide batts get put into 14.5" cavities, and 23" batts get put in 22.5" cavities. I have never seen a batt that didn't fit into a cavity.
Are you spraying the roof decking or the attic floor? If you are willing to spray the attic floor, you can spray enough foam to get the appropriate vapor barrier, then blow over it with the blown insulation of your choice. This is a budget friendly way to get the air sealing of the foam and the less expensive R's from the blown insulation.
For example, get 2" of foam blown on the floor for a R-14 and an air seal, and then have 12" of blown insulation installed over it, to get another R-38 for a total R-52 that will cost much less than the R-40 sprayed foam. Remember the attic floor has less square feet than the roof deck and the gable end walls, so the foam should be cheaper and you will have less area to lose heat from.
