Posted By Ona on 10/17/2009 4:46 PM
Thank you both for the quick responses.
Dana1 ~ I was hoping you would respond since I've seen how knowledgable and thorough you've been with other responses... thank you. I have already sealed all the gaps from the basement to first floor that are obvious. I was not planning on insulating my basement walls, rather just the sill box at the top of the foundation for now. Do you think it's still worth it to start this winter with the sill box and work on the walls later? Also, when you recommend unfaced rigid insulation, I expect the stuff that I was planning on using is out... I was looking at 2" rigid with foil faced. Do you recommend that I get it without the foil even for the sill box?
Wes ~ thank you for responding to my water issues and sharing that link with what looks like a fairly simple system. We do not have a sump pump. We don't normally get enough water for flow, its typically just wet spots at the cold joint, sometimes all along the cold joint. Rarely, we've gotton some flow (~3 times in the past 7 years). When that has happened it can flow out through the garage door typically helped along with some brooms.
Thanks Again!
If you use foil faced iso or poly-faced EPS on the walls the ground moisture will wick into the sills and they'll rot(!). 3" unfaced beadboard (EPS) will have the same ~R12-ish insulation value, but will allow the foundation to dry inward (rather then upward). (I used fiber-faced 3" iso in my fairly damp basement, and when I pulled a chunk to re-locate a drain this fall there was no evidence of any mold- it's drying to the interior just fine, the sill & band joist look fine, all is good.)
Dicing up foil faced iso for the band joist is OK as long as you don't have foil faced sheathing on the exterior walls. Be sure to foam/caulk the seams for best effect. It's best to foam-seal the joints prior to insulating it, and often it's just as cheap (and a lot less labor) to go ahead and just insulate it with foam at the same time, depending on just how much you need. Figure on 1" thick spray foam for R6, 2" for R12, and count up the board-feet (1" x square feet) to figure how much you need. If its' close to any of those those handi-foam tiger-foam goo-goo foam whatever closed cell kits it could be few hundred well spent- reducing the time to an hour or two, not days, with greater assurance of a good seal. (100bd-ft kits run ~$250, 200bd-ft ~$350, delivered.) A 1 car garage would likely only need ~100 board feet even if it had foundation sills to seal on 3 sides, but measure what you've got, read the installation instructions for these kits & decide. If the rigid board is already up you can seal/insulate right over the interface.
