Posted By Buntly on 01/28/2008 10:57 AM
Seems to me using the plus panel below grade where the temp is relatively stable would not be beneficial. Just curious to see what others think on this subject
Bunt
First of all, my condolences for having to use Quad-Lock. Good luck.
Second you're right Bunt, about a component of concrete's benefit being to moderate temperature swings; but also it serves as an energy reservoir, storing heat. I think the thicker external foam will further isolate it from the earth's heat sink so the benefit's there.
But you're also right about the thicker foam above-ground. More insulation is never bad, and if I had a choice I'd carry a block with 3" outside and 2.5" inside. (as long as it's not QL or the like... block strength is important)
I suggest you influence them to use Plus for the whole structure.
