Just posted this in another thread, thought it would be a good add on to this one.
The following segment is a very good basic
read about Equivalent R-Values. It is taken out of Ivan S. Panushev/
Pieter A. VanderWerf's publication "Insulating Concrete Forms
Construction: Demand, Evaluation & Technical Practice".
This took me a while to scan and edit but I think its content is worth it. Nothing too technical, just practical.
Equivalent R-Value
This is one of the most confusing things about energy efficiency, but you're
going to hear about it and you'll probably have to explain it to buyers at some
point. So you'll have to learn it. You can do it now or skip this section for a
week and come back when you're feeling up to it.
Heres the basic story of equivalent R-Value. Suppose I have a frame house and
an icf house of the same design. The ICF house uses less energy for heating and
cooling. The owner of the frame house might say, "That's because its walls
have a higher r-value. There about an R-20 and mine are only R-10". So He
might come up with a plan to get the same level of savings as his neighbor. He
might tear down his house (ok this is only a story) and rebuild it with thicker
walls that have more insulation. And he might make sure the work is done well.
And by the time he's done he might truly and honestly have frame walls that are
R-20, the same as the ICF walls.
So, will he now have the same energy bills as his neighbor in the ICF house?
Well, no actually he won't. The higher R-value walls should cut conduction to
be the same, but the ICF walls still get some additional savings because of
their lower air infiltration and their high thermal mass. So now someone
selling ICF's says to himself, "You know, when people go out shopping for
houses and they compare energy efficiency, they always look at R-value and
that's about all they look at. But that's not fair. Our walls rate about twice
the r-value of frame walls, but even if the frame walls were built so that you
doubled their R-value, our houses would still use less energy because we have
lower air infiltration and higher thermal mass. So when they look at R-value
they only get part of the picture, and I can't get them to look at anything
else."
But the ICF salesman could have a bright idea. He could say to himself,
"You know, I wonder how high you'd have to jack up the R-value of the
frame house to get down to the same energy bill as the ICF house?" Then he
could pay the owner to rebuild the frame house again, making the walls
thicker and adding more insulation until he got the fuel bill down to the exact
same amount as the ICF house. Because the frame house never gets the same
savings from lower air infiltration and from thermal mass, you have to keep
stuffing insulation into the walls to try to compensate.
Now the ICF salesman goes out and tells people, “An ICF wall has an equivalent
R-value of R40. By that I mean, to get the same energy bill as an ICF house you
would have to build your frame walls so that they were R-40.. So building with
ICF walls is equivalent to building with R-40 frame walls."
Now the ICF salesman has an R-value number to hand out that gives people some
kind of idea of the total energy savings from ICF walls. Equivalent R-values
this high are not unusual. A few years ago, engineers at Construction Technology
Laboratories did energy consumption estimates for ICF and frame houses that
showed that a house with ICF walls would still have a lower energy bill than
even an R-38 frame wall constructed with 2 x 12 studs, So that means that their
equivalent R-value would be somewhere over 38. And this result holds for
different climates across the United States.
The report of this study is titled Energy Use Of Single-Family Houses with
Various Exterior Wall Systems. Home people refer to it and if you want a copy
you can order it on the www.concretehmes.com
web site or at PCA Publications (800-868-6733).
A lot of people find equivalent
R-value to be a useful way to summarize the energy efficiency of ICFs. And
whether you do or not, other people will use it so you might as well know what
it is. But there are a few important cautions. First, equivalent R-value is not
the same as the conventional R-value and you shouldn't pretend it is. ICF walls
are not R-40. They still allow heat to conduct through like R-20 walls because
that's what they are. It's just that they have other, different ways, to save
some energy, Equivalent R-value is a way to boil all the energy savings down
and summarize them in one number, But it's a different type of number.
<!--[if !supportLineBreakNewLine]-->
<!--[endif&93-->
Second, there's no good way to figure out total fuel bills
from the equivalent R-value. If a frame wall has an R-value of 10 and an ICF
wall has an equivalent R-value of 40, that does not mean that the ICF building
will have one-quarter of the fuel bill. Without an engineering degree, all you
can really say is that the higher the equivalent R-value, the greater the
energy savings.
Third, the equivalent R-value depends as much on location as it does on the walls.
So a certain ICF wall doesn't really have a set equivalent R-value. The equivalent
R-value of the same wall could be 50 in St. Louis
and 40 in Miami and 30 in Edmonton.
The thermal mass savings are lower in extreme climates, and so the equivalent
R-value is lower.
Fourth, just to confuse things even more, some people
use a different term than "equivalent R-value? Some call it effective R-value
or mass-corrected R value, but they all mean about the same thing. So use
equivalent R-values carefully. They're kind of neat, and they can get across
the idea that there is more to energy efficiency than what the conventional R-value
number tells you. Just don't pretend that they tell exactly how
much energy you can save in a particular building.
