Hi all,
Just came across this forum so apologies if my question has been asked
previously.
I am currently at the planning stages of my first home and hope to use ICF for
the exterior walls. This is due to a number of reasons including air
tightness/low U-Value/sound, etc, and that i will be able
to able to erect the system myself thus cutting out the cost of labour on site.
{I was a foreman over a site of 10 houses which used ICF}
Currently there are a number of companies in Ireland with a franchise for ICF
systems - Nudura / Reward / Amvic etc. These are supplying 8" and
6" ICF blocks with only one choice in EPS width of about 2.5" [65mm].
I am interested in having a greater width of EPS panel perhaps 4" [100mm].
So I would be looking for an EPS block with 4" EPS - 8" concrete -
2.5" EPS. This is to up my wall U-Value to achieve PassivHaus standard.
I am interested to know the supply only cost
per sq.ft of any system you may know of, but especially the likes of Nudura as
I can make a direct cost comparison. Due to the sub prime debacle [ hope things
bounce back cos we need big US industry too!!!] the dollar is pretty weak
against the euro [1 euro -$1.57 today]
so if I can cut out the middle man in Ireland and ship direct from the US it
would be great. [East Coast of the US - New York/Mass/Rhode island/ Conn etc]
If you could also just mention the spec of
the ICF – EPS thickness etc.
Thanks & Kind regards
CMA
<!--[if !supportLineBreakNewLine]-->
<!--[endif]-->
