American Polysteel
For Advertising Info,
Find a Green Building Pro
Browse Project Albums
View Product Guide
Forums > Green Building Technologies > Insulating Concrete Forms (ICFs) > Subject: footings for icf on bedrock - proper method to level
06/09/2008 11:16 PM
Good info Chris! I had heard alot of that watching 'Modern Marvels' awhile back. I just don't understand why they would build these huge bridges attached to bedrock in siesmic areas (CA) but the code says you 'can't' do this with a house??
buddenUser is Offline
06/09/2008 11:20 PM
Pretty close.  When the Brooklyn Bridge was built, it was something of an engineering marvel of the day.  And they had to go through a lot of muck to get down to the bedrock, just as you've noted.  So the engineer put caissons in place where the piers would go -- essentially a large-diameter vertical pipe with the top sealed.  Pressurize the caisson so it won't admit water.  The work crews would airlock inside and dig.  As they went down, so did the caisson.  When they got to the rock, they stopped digging and the caisson stopped sinking; it's now a form for the pier.  (This recitation from memory)  I recall from the reading the digging job was not the safest occupation in the world.  Or even New York.
Bruce FreyUser is Offline
06/10/2008 6:46 AM
Posted By Chris Johnson on 06/09/2008 8:51 PM
Well...here is my dumb answer...
A bridge requires a pre determined depth into bedrock to provide not only shear stability but also to 'lock' the sides of the piers to help prevent it from moving/shifting under stresses caused by several factors including...but not limited to vehicular traffic (Live Load) Wind loads (TBD), sheer weight of the structure itself (Dead Load).
Without properly anchoring the structure to the ground the dead load by itself could very well allow the structure to collapse as the piers would be able to slide out and skid on the surface. Now if that didn't happen but you add a live load which would be causing harmonic vibrations the undue stresses could very well make everything shift and slide...hence, dig into bedrock and lock it in.
Not a dumb answer!  Every structure must deal with some horizontal loads weather it is from wind, seismic or other dynamic forces.   Keying it into bedrock is certainly one way to do it and is probably the case in the bridge example (although in seismic areas large buildings are also likely to be built on rubber or sliding dampeners  to control motion).
On massive structures like bridges and tall buildings, the bearing capacity of the underlying material is very important.  When building on rock (especially limestone), the upper interface with the overlying soil is likely to be 'weathered' (i.e., cracked, fissured, with veins of soil).  This weathered material must usually be removed to get to sound rock and is probably the most usual reason for rock excavation.  The cores (stairs, elevators, restrooms, etc.) of tall buildings typically have higher foundation loads than the perimeter and care must be taken to minimize differential settlements, so sound bearing is important.
Just as an aside, the bends (nitrogen bubbles in the blood) was also known as "caisson disease" because the poor souls working in pressurized caissons frequently suffered from this problem.  They were definitely not nice places to work.
Bruce
Forums > Green Building Technologies > Insulating Concrete Forms (ICFs) > footings for icf on bedrock - proper method to level
Professionals Serving
Your Location:
Sierra SIPs (San Andreas, CA)
View More
GBT Project Albums:
magnolia remodel (seattle, WA)
Cottage (Rio Nido, CA)
Our new house (Burt, MI)
The RANCH (Williston, SC)
off grid SIP modern house kit (Charlotte County, VA)
More Info |  Search
