Here are a couple of videos showing how we did a FPSF with integrated radiant heating. The only thing not show is how we treated the exterior of the slab. For this we put a plastic vapor barrier, 2" of Polyiso insulation, wire mesh and then parged the wire with a stucco mortar mix. In MA we are required to insulate not only the exterior of the slab, but also 3' out horizontally from the bottom of the slab. If you have a copy of the IRC building code book it shows this. We not only insulated out from the slab but under the entire slab with 3" of Geofoam, a high density EPS designed for this purpose and has an R-value of 15.5
http://www.youtube.com/watch?v=J7ICP024ogw&feature=channel_page
http://www.youtube.com/watch?v=JkXceHPU7zw&feature=channel_page
Tom Pittsley
[email protected] www.eebt.org
