as distributors and state certified builders we have been planning and building in coastal areas with icf walls since 1995, and with insuldeck floors and roofs since 2000. our builders and distributors have built 2 and 3 stroy elevated structures on all types of foundations. we cover the south east and have icf distributors in virtually all states who can help you with your project.
if you send me an email i'll be glad to put you in touch with experienced distributors architects and engineers, and email you our cd with hundreds of project pictures and techinal information.
[email protected]depending on soil conditions you can put a multi story icf structure on all foundation types that are designed to handle the weight of the structure.
ie:
augered cap rock with 4'x24" concrete plugs and columns above...(not on obx)
all others likely:
jetted or augered timber piles with concrete pile caps and grade beams/concrete columns above...
augered concrete piles, prestressed, water jetted or driven concrete piles...
helical screw piles...
and many more....
a capable structural engineer, familiar with concrete design is the key here.
as is finding out beforehand what piling methods/contractors are availbable on obx.
concrete availability should not be a problem there.
peter
