ICFs and architects
Last Post 30 Oct 2009 11:29 AM by rykertest. 14 Replies.
RobertJHMUser is Offline
15 Oct 2009 06:52 PM
Does anybody know of an example of a respected architect who chose to build an affordable residence of any kind with ICFs?
NicoleCUser is Offline
15 Oct 2009 08:08 PM
Debra Rucker Coleman
Why do you ask? Most any plan can be converted to ICF or vice versa.
15 Oct 2009 08:20 PM
I'm doing a book on architects and builders using prefab building systems– including ICFs – to achieve sustainabiliy, i.e.green building.
15 Oct 2009 08:28 PM
Ah. She's more of a passive solar gal, but ICF and SIP are both in her toolbag.
15 Oct 2009 08:48 PM
Thanks. The question doesn't require expertise, it's just a matter of random knowledge.
ICFengrUser is Offline
16 Oct 2009 12:09 AM
Hello. There is nothing related to prefab and ICFs.
16 Oct 2009 12:35 AM
OK
smartwallUser is Offline
16 Oct 2009 07:08 AM
Don't be too sure, icf's can be perfabed.
DebTFUser is Offline
16 Oct 2009 10:18 AM
For pre-fabbing using ICF's please take a look at this video:
http://tfinsulatedconcreteforms.com/index.php?option=com_content&task=view&id=63&Itemid=98
16 Oct 2009 11:00 AM
Hello DebTF. The link you are referring shows the prefabricated forms not the finished wall.
The ICF is the concrete form. The concrete itself is cast in place. There is some sort of related to ICF work that it may be considered prefabricated and that is "tilt up walls" using Insulated Decking (like the ones from "insul deck" and "quad-deck").
16 Oct 2009 11:34 AM
Thanks to everyone responding but I know what an ICF is and how construction with them works.
I'm defining ICF construction as a "prefab" or at least "alternative" building system compared to standard stick for my purposes.
I am looking for an example of residential design design by an architect which was then built. Thanks.
DallasBillUser is Offline
27 Oct 2009 03:48 PM
Go to http://www.w2-studio.com/
Go to 'Projects' and then 'Residential' within Projects.
Select 8605 White Rock.
You will see our home, built in 2004/2005.
Amvic ICF.
27 Oct 2009 05:32 PM
Posted By DallasBill on 10/27/2009 3:48 PM
Amvic ICF.
Which one of the residential projects is it, the one on Clayton?
28 Oct 2009 10:54 AM
"Select 8605 White Rock."
rykertestUser is Offline
are you looking in a certain area or nationwide? I have a few I deal with that use and are open to ICF's.
People Online People Online: Visitors Visitors: 233 Members Members: 0 Total Total: 233
