I am trying to understand the thermal bridging question with regard to steel SIPs.
Can someone explain the difference to me regarding thermal bridge for the following two scenarios:
1. Building off site a regular framework of 5 1/2 " light gauge steel stud panels ,18 or 20 gauge, (16" o/c), 4-8-12' sections, cavities filled with PU insulation , and one or two electrical chases per channel. After installing on site by normal methods, adding an exterior cladding of OSB, moisture barrier, and a layer of 1-2" of EPS.
or
2. Utilizing a product like Thermasteel or Platinum Advanced Technologies which both seem to be engineered with EPS between steel studs without an internal external connection and utilizes EPS as the insulation.
In the first case scenario I believe the exterior cladding would prevent the bridge but perhaps not as effectively as the spaced non connected stud design in commercial products.
I would appreciate any insight.
Thanks.
Clancy
