Posted By moibiusmuse on 01/21/2008 9:54 PM
"While I was initially very excited about using SIPs for these homes, some doubts have crept in that I am looking forward to addressing in more detail with the manufacturers. One of the main issues is our party walls in Philadelphia that must achieve a 2 hour fire rating in between new homes. One and possibly even two layers of SIPs will most likely not solve this requirement.
An additional layer of drywall will solve this problem.
The other issues is how to support the roof panels. If an extensive beam or truss system is required it will increase our material costs, effect our interior appearance and increase the need for traditional framers on the jobsite.
The need for beams depends on the span and load applied to the roof panels. We would need further info to give them an opinion.
Lastly, I have received some conflicting opinions on SIP assembly, sealing and exterior cladding that I am hoping to clear up and educate the team further on as we are all fairly new to SIPs and have no personal experience with a SIP project in Philly."
Assembly and sealing would depend on the SIP system. In some cases the system's are easy for the novice to install correctly, and in other cases they require a professional.
