Posted By rarickert on 03/09/2008 1:36 AM
With basement SIPs... if you leave your basement unfinished, do you still have to drywall (cover) the interior SIP wall?
I read that with ICFs... in an unfinished basement you still have to cover the interior foam.
I was wondering is SIPs were the same or if the interior OSB ply was an acceptable covering.
rarickert;
this is a code related question and most codes require for "finished" areas a 15 min thermal barrier over "plastic" insulation, EPS is considered plastic. Normally 1/2" drywall is used.
I am not aware of a requirement for "unfinished" areas needing a barrier, I would not think that a building official would require the OSB be covered, but it is a matter of iterpretation of the inspector and at their descretion.
We always leave the inside of garage exterior walls on our steel SIP panels bare, as well as the garage ceiling (if there is no living space above)
