sip w/ peel and stick
Last Post 18 May 2008 05:35 PM by chuck07. 3 Replies.
jvwittUser is Offline
04 May 2008 04:38 PM
is it safe to install peel and stick membrane on sip roof and walls
04 May 2008 04:58 PM
Posted By jvwitt on 05/04/2008 4:38 PM
Opinions differ, but the consensus is no. You always need a way for a structure to dry if it gets wet(it shouldn't happen, but if it does). With SIP tape (should be required) on the inside, the outside is where the moisture must go.
I do recommend a 'peel & stick' membrane around all openings(extending inside) and at the exterior corners.
NickCUser is Offline
16 May 2008 01:03 PM
You mean like on the  front cover of JLC Feb, 2008? I remembered this as I was reading it just the other day. I am not SIP knowledgable, but why not on a roof?
Nick
chuck07User is Offline
You need to consider what the climate is where you are building.  What work best up north does not work the best down south.  Hot, humid climates dry toward the inside, Cold heating climates dry toward the outside.  This determines what side of the wall assembly to seal and which side to allow for drying of the wall assembly.  Building Science gives some good information about this http://www.buildingscience.com/bsc/.  The publish books regarding best building practices in different climates.  They even have a new book on building with SIPS but I have not had a chance to look at that one yet.
People Online People Online: Visitors Visitors: 197 Members Members: 0 Total Total: 197
