PWF floor systems have been around as long as PWF walls. We actually used one here in KY about 15 years ago with an ICF wall system. To my knowledge it works just fine. The key is lots of clean wash rock fill under the floor system with drains to divert groundwater. And a double layer of 6 mill poly with seams taped under the floor system. Our system used 2x4 sleepers on the rock, then the poly, then 2x6 floor joists and 3/4" plywood, all .6 retention CCA PT. |
