In the thread entitled "Sip ageing test," it was concluded by
Louis Fisher of FisherSips that bottom line Steel sips are a better product but
ultimately it is the cost that drives the industry, so if you are counting the
cost over the advantages then OSB is your better bang for the buck. However this has not been my experience as an
owner builder. In 2003-2004 I faxed my
floor plan for a two story 32 X 60 home to the top ten panel makers listed on
the Sipweb page, this included FisherSips, PanelCrafters, R-Control, MarquiseConst,
Value build etc I received a bid from each of you
and the average bid for the sip “kit” was right at $40K for the kit alone. The bid that I received from Marquis
Construction, now called SouthernSips, for steel Sips was $68K. The difference however was the steel sip bid
included a Steel Sip roof instead of a conventional roof system. The steel bid included all labor to erect the
house making it “trade ready” meaning second floor in and all interior walls
framed out. The steel bid included Simonton
windows that are double pane, low-e, argon filled. So My Steel Sip house of 3981 sq ft total,
trade ready, with the windows and doors installed, came out to just under $18
sq. ft. And was trade ready in 9 working
days, with a four man crew. To install
the windows and doors took another 3 days.
My friend Mack who built at the same time using OSB, for 54
X 36 two story, after the rental of
cranes and extra labor, with a conventional roof, came out to just over $25 sq.ft.
and that was without windows. As someone pointed we have to live in the real
world not the theory and maybe. For what
it is worth my experience says I did better in product and price with steel sip.
